North Coffee TJ-067 / JYR-1DA Roaster Early Discovery Notes
- slickrock
I've been gather notes on this roaster and thought I should get a post going.
Some weeks ago the forum was hit with news of the upcoming next-gen high-capacity Hottop, but the heavy interest in this long-awaited roaster gave way to lamentations of what many considered to "way too high a price" for the likes of a roaster whose specifications don't seem up to snuff against commercial grade alternatives in the nearby $6K range. I fell into the group and noticed that the ensuing backlash led forum participants on to survey low-cost alternatives for those wanting a large-capacity roaster, commercial quality roaster, at least in the 1kg range (after all the new Hottop was claiming a 2kg capacity), for the home enthusiast. Sure enough, the recent onslaught of low-cost Chinese roasters surfaced in these discussions, many of which have either unknown or dubious track records. One roaster, however, caught my interest: the TJ-067 from North Coffee. I've since been in contact with the company and thought I would share what I found so far, since the time seems ripe as new threads have popped up regarding other Chinese roaster entries.
The whole next-gen Hottop letdown got me thinking about what I'd want out of a large-capacity commercial roaster for the home enthusiast, some of which include:
Regarding damping and ventilation, the roaster appears to have gone through a design metamorphosis over the last 1.5 years and if you pay attention to the photographs on the web site, you might be led to believe that they are different roasters models, when they are in fact they are versions of the same model, as outlined as follows:
The first version had a damper with adjustment wheel and exhaust fan mounted directly on the chimney, where ventilation was only controlled by the damper on concert with a fixed-speed fan.
I have to admit the damper control looks cool but this version gave way to a second version that dispensed with the damper and moved the fan to rear of the roaster, but in exchange offered full fan speed control. The cyclone would connect to fan by a flex hose (not pictured).
The third (and current) version moved the adjustable-speed fan off the roaster and onto the cyclone itself, supposedly to improve chaff collection and flow into the cyclone, but this means the flex-hose needs to attached to front of the roaster at the chimney, and to these eyes, this looks cosmetically worse and hose sag may cause ventilation issues.
As such , I suggested to North Coffee to consider making a stainless pipe attachment from the roaster to the cyclone to create more integrated setup, as per what can be found with a Mini 500 or Cafemino. After a few weeks, they took up this suggestion, (and mind you I have no business affiliation with the company) and provided and updated version, that looks a lot better IMHO:
Regarding requirement 5, the thing that got me going on this was the thorough early adopter experience of TJ-067 roaster shared on this coffee forum from down under: crema coffee forum
Here, there's some good mod-friendly feedback (retrofittable parts, easy access, etc.) on the roaster and the roast profiles show both low drop temps and fast turn-arounds with 1kg loads that seem to imply that the roaster can operate well at this sweet spot, which is particularly interesting considering that this is the electrical version of the roaster being exercised. One would assume that the gas version could easily be pushed further into 1.5kg territory.
Finally, regarding requirement 6, it looks like this beast can be had for a price well South of the going price for the impressively well-built commercial-grade Mini 500 (thanks Henry for the demo) and less than half the price of what the next-gen Hottop is rumored to go for. Shipping seems reasonable, though destinations appear to be only to west-coast ports: for California, its Oakland and San Pedro.
Anyway, this is what I came up so far and personal interest is still brewing.
- At least a true 1kg capacity sweet spot, which implies that roaster should support about a 50% greater capacity than its specified rating.
- Realistic power rating and delivery to support the above sweet spot.
- Minimal proprietary design and automation, so that it can be self-serviced, augmented, and maintained, even if the company that sells it later disappears. As such, it should also be easily PIDable and TC4able.
- Substantial design (read heavy and overbuilt) with strong ventilation control and cyclone-quality chaff collection. Plus tryer, temperature instrumentation, and other sundries one would expect from commercial drum roaster.
- At least some hint or semblance of a track record to go on for the early adopter (this comment assumes that established companies won't be offering their roasters at deep discount prices to meet the following requirement).
- Very cheap price, as in high value for what you get - after all this would be for the advanced enthusiast at home and people of this ilk do enjoy a good bargain.
07/11/1991, 08/21/2017, 04/08/2024, 08/12/2045
- cygnusx1
I checked out their website and they have several different 1kg units as well as larger roasters. Pretty neat stuff. I'll be interested in the feedback on your post. This unit is probably beyond my scope at the moment. More than likely I will be getting a HUKY 500. Whirly-pop roasting has gotten quite old quite fast.
- TomC
Very cool! Thanks for sharing Joel!
- JavaMD
Thanks for the post on the TJ-067
Any Idea what the readouts that are presently on the roaster give ...
and now that they went from two "dials" to one .. what it controls.
Give us feedback if you go for it ... interested ..
Steve
Steve
- slickrock (original poster)
The two digital readouts are for temperature and timer. I believe you can set both temperature and time alarms, but no PID for profile control. Judging from the crema forum, it looks like there's plenty of space to retrofit this digital components with a PID to control a roast profile. Or better yet a TC4C hooked up to Artisan or RoastLogger to automate profiles as far as one desires (the electrical version being the best to automate in this regard).
I failed to mention in the prior post that the pictures of the roaster alternate between the electrical and gas versions, where the knob count differs. The latest rendition of the roaster has 1 knob (fan speed) for the gas version and 2 knobs (fan speed and power control) for the electrical version.
Although I'm very interested, I'm a bit illiquid on the asset front at the moment, so things will have to wait for little while.
- beanflying
Just checking in and subscribing to the thread. Mine by the way has been faultless for over a year and roasts very consistently.
Levers RULE :-)
- JavaMD
Beanflying, and all
Would you get the electric version or go for gas ... I'm leaning toward LPG - propane.
Steve
Steve
- saoye
I ordered the Electric version and 2 weeks later it is being loaded onto the ship. Now I have to wait patiently for a big crate to arrive at my doorstep.
Thanks for the post slickrock, very informative. Also Beanflying has plenty of experience with using the original 1kg design and it's good to know that it is still going strong. There is also another 1kg coffee roaster being sold on Amazon and ebay with an analogue temperature reader near the tryer. Looks very nice but is half the weight of the Northcoffee roaster. Heavier does not necessarily mean better, but to me it is a good indication of quality of the build.
- beanflying
In the US the biggest reason not to go Electric would be your 110V unless you aleady have a 220V circuit at home. The other major benefit of gas over electric is slightly quicker response time to heat changes but you just need to learn to deal with it (proactive not reactive) earlier. Technically in Australia this sort of device would require gas certification in particular if it was going in a commercial setting.
Also don't 'assume' North Coffee are necessarily the manufacturer because they say they are, plenty of Chinese companies claim to be the manufacturer of all sorts of goods and are in reality just reselling
Levers RULE :-)
I am looking to get TJ-005 from them , they said i can store roast profile but have to make sure about this. The machine doesn't have adjustable drum speed but they said it can be added with extra fee , do you guys think it is something i should get ?
Also beanflying will you please send me bank account number or paypal email they use to accept payment ? I just want to cross check before dealing with merchant without using escrow.
Thanks
Thanks
