New Kaldi Fortis Setup - Page 2
That is the plastic one. I've been using it for light duty roasting setup.
Nope, been using weekly, works perfect. Actually, does get pretty hot, and the input has warped a tinny bit, but this thing has been going for a few months without any issues. I would think it depends on how many roasts you do in a row,and do you let the system cool between roasts, that's what I do.
Love my Kaldi, check out my bean cooler, works amazing.
DIY Coffee Bean Cooler
No melting yet, has been working solid for now. I will upgrade to a cast version soon, but so far, working perfectly.
The small aluminum one?dtrevino15 wrote:cast version
The inlet of mine warped more so I cut some off and inserted aluminum pipe as a surface to clamp the exhaust duct onto.dtrevino15 wrote:the input has warped a tinny bit,
If the whole thing doesn't hold up, I already have a plan to make a cyclone chaff collector out of stainless steel kitchen gadgets.
Good idea, let me know what you build, I may want to copy you
I'm about to pull the trigger on a Kaldi Fortis, but trying to figure out the best way to vent it. Love your setup and was wondering how it's working for you.
Any thoughts?
Any thoughts?
I'm not him but I do use the same cyclone collector for chaff and exhaust. It's still holding up. Following pictures are how I have mine set up. Blower fan came with DC motor (eBay) which I use 24VDC wall wart with PWM controller from Amazon which allows me to adjust fan speed from 60 rpm to 3000 rpm. Because of this adjustable range, I don't need a damper to control airspeed. The chaff collector is aluminum box from Amazon which I cut out the side for hinged door made out of 1/8" thick plastic panel.
Hope this helps.
Hope this helps.
