New in roasting, how to understand the graph - Page 2
- MNate
Awesome. Your roaster looks like it has good control.
Often people go the opposite: starting with higher power (but not so much you scorch the beans) and dropping lower as you go. I'd definitely try the one setting throughout though and see what things look like.
(You'll want to better see the rate of rise info though so scaling your graph so it takes up your whole verticals space will be better).
I'm hoping your second posted roast tastes a lot better than your first! It looks like it should.
Good luck on your roasting journey
Hi Imahai,Imihai wrote:I used 100grams
I tried to see what the machine can do. After posting here I went to find some books about roasting and now I have some ideas, about RoR or deltaBT and also I understand why the time should be as it is.
I'm looking at this same roaster, but am tossing up between the 150G and 300G models.
Would you be able to answer some questions for me ?
- you got the 300G model, but you said you did some 100g roasts, how have they turned out ?
- the machine allows you to program some profile curves, how many profiles can be stored
- can you program the curve for both temp and fan speed
- how difficult have you found programming it
- what are the dimensions of the glass chamber, i've read the 150g model may be a bit short, causing the beans to pop into the chaff collector
Hi, very interesting I have the same roasted than you
in fact the previous model D350G
I have just made my first roast monitored with artisan, I was a bit overloaded by evens, but very fun.
[youtube] http://www.youtube.com/watch?v=NciMoK7dLeg[/youtube]
You should choose the 300, 150 it's really small.Adam.M wrote: I'm looking at this same roaster, but am tossing up between the 150G and 300G models.
Would you be able to answer some questions for me ?you got the 300G model, but you said you did some 100g roasts, how have they turned out ?
I use 240gr for experimenting and max 300gr, 300gr you get 250gr roasted.
6 profiles of 6 steps.the machine allows you to program some profile curves, how many profiles can be stored
No only temperature, fan is only drived manually!can you program the curve for both temp and fan speed
Programming it's easy, get the desired result or at least an interesting result that is another story. But same issue with all roasting machine. But Artisan should help.how difficult have you found programming it
NoIs there a user manual that you think you could share ?
Maybe there is some differences with the new model
thanks for your response iPa64iPa64 wrote:You should choose the 300, 150 it's really small.
No
I actually bit the bullet and got the 150g model, have managed to bring 150 grams of old beans to second crack in under 11 mins. plenty more to experiment with.
I actually intend to do a teardown of the machine over the weekend to get some details of the hardware capabilities.
