Mixing a soldering station and a popcorn machine...
- lassepavoni
Looks like I just fell down another rabbit hole. Some discarded stuff and a couple hours in the workshop produced this intimidating contraption. Fan speed is fixed for now, temperature is adjustable between 100°C and ~250°C. Guess I'll have to order some greens to put it through its paces now
Regards,
Lasse
Lasse
- Randy G.
check the "building a roaster" section of https://forum.homeroasters.org
Lots if folks there that done things like this and a lot of them ever crazier.
www.EspressoMyEspresso.com
* 22nd Anniversary 2000-2022 *
- lassepavoni (original poster)
Yeah, definitely plenty of options from now on
Regards,
Lasse
Lasse
Roasted my very first batch today. Totally underestimated the power of that little popper though and started out waaay too hot. I put 100g beans in with the fan running already and then switched on the heater. The first tipping and scorch marks didn't take long to appear... Ended up a rather fast and rather dark roast, but it might still be palatable. Some beans ended up chipped, but not totally charred
. I'll let them sit for two days and then try how they taste. In the meantime I'll run the next batch through tomorrow
Regards,
Lasse
Lasse
I certainly tried to. The fan was a little weak to accomplish that on its own, so I assisted stirring with a stick.
Now I have rewired the fan and it gives a nice steady swirl to a batch of 100g greens. That's a little on the high side towards the end of the roast, so I should add a speed controller.
The second batch now turned out a lot better then. It went much slower (was too excited to set up a stop watch
) and looks nice and ''dry''. The first batch turned out extremely oily, almost like it was sauteed with a lot of butter... Still got some tipping and chipping though.
Beans are arabica from jinotega, nicaragua.
Regards,
Lasse
Lasse
stirring works. also I had my fan 'over boosted" at the beginning. Fan power can drop by around 30% during the roast. The belly in a hurricane lamp can let the beans move to the side and drop back down outside of the main air plume.
