Humidity sensor on exhaust - other gas sensors ? - Page 3
Esteve (original poster)
#21: Post by Esteve (original poster) »
Really cool sketch! Something like that should work.
I think the sensor I got is the one with the membrane :Board Mount Humidity Sensors SIP 4-Pin w/ Filter Resists Condensation
And I believe you are right, the heating phase is not indicated by the led... maybe at the end a couple buttons for signaling : Heating, CC, FCs, ... would be an easy solution.
Here is a closeup , I cleaned a bit the sensor board:
GDM528
#22: Post by GDM528 »
Esteve wrote: the sensor board:
Is the sensor board just wiring? Some (but not all) I2C hookups require a pullup resistor, but that could be tacked onto the processor board so that it's just fly-wires to the sensor.
Any issues with alternate ESP32 boards? For example, there's a version with an integrated display that could be handy https://www.adafruit.com/product/5483 This board also supports CircuitPython and STEMMA QT, making it more accessible to a wider range of hobbyists. It's plug-in compatible (no soldering!) with a different HT sensor board https://www.adafruit.com/product/2857 which has a higher operating range (80C). A further benefit to the STEMMA QT interface is chainable, plug-in access to an ecosystem of yet other potentially interesting sensors, like CO2, VOCs, so you could turn this into an exhaust-gas analytical lab ;)
#23: Post by Esteve (original poster) »
The sensor board is just the i2c pull-up and wiring. The main thing is the pitch of the humidity sensor, it's a 1.27mm, so I have a small converting board and pins to 2.54mm.
The i2c pull-ups could also be on the main board. I think i2c can do up to 1 meter without many issues.
Regarding the board, the ESP32 is so cheap... has great connectivity, it comes with Bluetooth and Wifi. Ample memory and decent processor.
And actually I didn't want to bother with the ESP32 frameworks, it's the first time I use the ESP32. So I ended up programming it using the Arduino libraries. I think you can also do micro Python.
If at the end this was to be an exhaust gas analyzer for Artisan we could go with any board and do communications via UART over usb.
GDM528
#24: Post by GDM528 »
The still-active thread "DIY Color Meter" may be a good architectural model to consider. It's approaching 700 posts and 9000 views, which may be related to the accessibility of the design. The photos in this particular post neatly summarize the component selection strategy: DIY Color Meter. That's what I'm contemplating as I think about how to shadow your results. Happy to hear you're using the Arduino libraries, and I bet the code architecture would port easily to Python, CircuitPython, etc.
GDM528
#25: Post by GDM528 »
Question for people with drum roasters:
Are there locations on your roaster where can access the roasting fumes separately from the heat source? The few pictures I've seen show what looks like a combined exhaust from the (electric or gas) heating system spillover and roasting fumes. Unfortunately, a combined exhaust would both dilute and potentially overwhelm the roasting fumes.
Are any of these approaches practical?
1) Replace or modify the tryer to draw an air sample right out of the circulating beans.
2) Hold an access door (load or dump) slightly ajar to slip in a 1/8 inch tube.
2) Drill a hole in your cherished roaster and insert a pipe fitting, somewhere in the range of 1/4 to 1/8 inch.
I'm presuming the air pressure in some drum roasting chambers may be net negative, with a fan downstream to pull out the fumes. So, this has me thinking the analyzer needs to actively pull the air sample. That may seem harder than it has to be (and unnecessary for the IKAWA), but this would also regulate and control the airflow through the cooling system to keep the sensor(s) from overheating. I'm estimating this would only add about $10 to the build cost.
Brewzologist
#26: Post by Brewzologist »
GDM528 wrote:The still-active thread "DIY Color Meter" may be a good architectural model to consider. It's approaching 700 posts and 9000 views, which may be related to the accessibility of the design. The photos in this particular post neatly summarize the component selection strategy: DIY Color Meter. That's what I'm contemplating as I think about how to shadow your results. Happy to hear you're using the Arduino libraries, and I bet the code architecture would port easily to Python, CircuitPython, etc.
Definitely recommend setting up a GitHub site for this effort. There is also a separate Discord channel for the DIY color meter or you can enable discussions in GitHub too. One challenge is having discussions among users/early adopters and those who are interested in the engineering; suggest you keep those separate. See here for code and Wiki: https://github.com/juztins-lab/roast-meter
Brewzologist
#27: Post by Brewzologist »
GDM528 wrote: Question for people with drum roasters:
My drum roaster exhaust includes both drum fumes and any heated air from the burner that comes into the back of the drum. Assuming this device has merit I wouldn't be bothered by drilling a hole for a new sensor. I don't want to use the tryer or access door because it will affect the temp inside the drum too much.
I have a fan that pulls exhaust from the drum so there is a net negative pressure. Not entirely related to what you are trying, but I have had a pressure sensor connected to my exhaust stream via a ~1.5ft length of tubing for a long time. I bent a piece of brass tubing pointing downstream and have never had it clog up.
drgary
#28: Post by drgary »
This, but no pressure sensor.
LMWDP#308
#29: Post by Esteve (original poster) »
Hi,
Yes, the DIY Color Meter is a great project.
Happy to contribute with the current architecture/ code.
However we should start by defining it :
- should it be Bluetooth?
- focus first on Ikawa keeping other roasters in mind ?
- do we target Artisan? Or custom app with "export" capabilities? Cropster is also really cool, and their API seems simple enough.
- focus on just humidity? Or multi sensor ? Currently I have 1 pt1000 and 1 humidity. But my idea was 2 humidity sensors, ambient and exhaust.
- do we just do the software or try the air cooling and enclosure ?
If there is interest we could discuss over Discord. Also GitHub is perfect to share the code. Some time ago I published the Ikawa Emulator if anyone is interested: https://github.com/esteveespuna/IkawaRoasterEmulator
GDM528
#30: Post by GDM528 »
If the interface is Bluetooth, doesn't that generally require a phone app? If I'm roasting, I'll likely be using the IKAWA app, so toggling between two apps would be a hassle. This is one of the key reasons I'm inclined to incorporate a display into the sensor. However, I may be displaying my bias because I don't create phone apps - maybe it's not that big of a deal?
Virtually all of the controller boards that have Bluetooth also have Wi-Fi, which opens up other ways to access the sensor data. For example, I use my desktop PC to SFTP .csv files off my temp logger via Wi-Fi, and eventually I'll have the logger just email the data. Getting logged into one's local network could be a barrier for some, so ideally the controller board would support WPS (I think the ESP32 boards might).
I concur that getting something working with the IKAWA first is a good place to start, given the Pro 100x is one of the few (only?) systems to benchmark against.
Initially, just producing .csv files should fine. It's not obvious to me if Artisan even has a mechanism for moisture data - but it might if this sensor works well and produces useful data.
Moisture (humidity) concurrent with chamber/exhaust temperature would be a powerful combination. I see the value in the ambient humidity sensor, but I expect it's readings would be largely flat during a roasting run, so there may be other ways to obtain the reading it would produce. Other gas and or particulate sensors would be highly experimental, brave new science that could be added later as long as the overall system architecture supports it.
As for system architecture, I like the approach taken with the DIY Color Meter: Use a controller board with a QWIIC connector to support chained I2C sensor boards. All available through hobbyist retailers like Adafruit and Sparkfun, who provide code support. I've only briefly dabbled with Ardunio before migrating to Python, so my personal preference is towards processors that support at least CircuitPython. It might be instructive if initially people are using different boards - that may uncover which one (or ones) are best.
I'm thinking about how to build the air cooling system and enclosure using commonly available parts and some 3D printing. For other projects here on H-B I've posted CAD files on GrabCAD and got no complaints about accessing the data. Is GitHub suitable for mechanical design data?
