How to store propane tank for lpg roaster - Page 2
- CarefreeBuzzBuzz
If you were referring to my doc, did you scroll down. You should see it. Seen me a PM with your email and I can send it. Your final connection may vary.BoulderMike wrote:Thanks for the response. I couldn't see the links though. Probably a Google thing.
- EddyQ
RV folks typically have propane outside and plumbed inside. They often leave the tank valve left open! And they typically have a propane alarm.Chert wrote:
This conversation makes me nervous about RVs. Many of them have a tank attached outside the rig (or two) how secure are all those lines taking LPG to gas, water heater, and other mobile appliances?
So we too likely could benefit from a properly placed propane sensor and alarm.
My tanks are always stored outside and I would never leave the valve at the tank left open. I also often check my propane connections all the way to the burner valve with a soapy water spray bottle dedicated to my roaster.
LMWDP #671
- CarefreeBuzzBuzz
I edited the security settings on the gas doc. If anyone still has problems let me know. It basically provides a 20 foot hose and quick connects that make it easy to set up and take apart.
