Home Roasters Tamping Thoughts - Page 2
I concur that tamping is perhaps the least important factor, as long as it's level you're good. There is though the thing that on Pavoni you might get a strong jet of water shooting from between the piston and the inlet hole towards the puck. In that case (and you will see a clear dimple in the puck if that happens) a good strong tamp may help mitigate the issue. Tamper and tamping force just happen to be one of the popular remarks people throw as a solution to whatever supposed issue, along with "grind finer".
Edit and full disclosure: I still use the plastic OEM tamper that I modified to fit perfectly in the basket, and I get pretty damn good extractions.
Osku
- drgary
I bow my head in your general direction. That roaster is on a much higher level than my humble iRoast. Very Very cool! Thanks for the picture !
Charlie
- drgary
FWIW I started with a FreshRoast, loaned to me by Alan Adler, the AeroPress inventor. That hooked me. Next, I bought a second-hand Hottop. Then I built a heat gun/bread machine roaster. I still have that as a backup.
LMWDP#308
LMWDP#308
- baldheadracing
I have a collection of iRoast2's - one for roasting small quantities, and the rest for parts. Someday Hearthware's patents on the roasting chamber design will run out and someone will make a better small fluid-bed roaster in what was the iRoast's market segment - but I haven't seen it yet.clynch wrote:I bow my head in your general direction. That roaster is on a much higher level than my humble iRoast. Very Very cool! Thanks for the picture !
