DIY Color Meter - Page 72
- yakster
I've been thinking about this and the discrepancy seems to be that I'm expecting 95 Agtron at first crack for ground coffee but that's the typical value of coffee at first crack for whole bean. The ground coffee values are going to be higher. I wish I had gone ahead and measured all four roasts first crack and roasted coffee samples now.yakster wrote:I pulled some samples at first crack but got some high readings ~118 where I'd expect something around 95 for the Gourmet Agtron scale and based on the Sweet Marias roast color cards I picked up...
-Chris
LMWDP # 272
LMWDP # 272
- Transparent Roaster
Yesterday I roasted 5-1lb batches of Ethiopian Guji Derikocha G1 natural beans... the goal was to try various lengths of development time post 1st crack to find the bean's sweet spot. It's very interesting to verify the differences in color, and then sample them to see how the flavor was affected. According to my color meter's calibration, the numbers are as follows;
Agtron 100 = 1 minute 20 seconds, dropped during 1st crack - 17%
Agtron 94 = 1 minute 30 seconds, dropped during 1st crack - 19%
Agtron 89 = 1 minute 45 seconds, dropped during 1st crack - 21%
Agtron 79 = 2 minutes from 1st crack - 22%
Agtron 75 = 3 minutes from 1st crack - 26%
- Brewzologist
I'm going to create a draft scale for the DIY meter similar to what EspressoVision did for their meter. Weigh in on the color ranges below based on your RM readings and experience. Yup, it ain't going to be perfect given grinder/prep differences but it's a start:
Very dark: ??
Dark: ??
Med. dark: 60-69
Medium: 70-84
Med. light: 85-99
Light: 100-114
Very light: 115-135
Very dark: ??
Dark: ??
Med. dark: 60-69
Medium: 70-84
Med. light: 85-99
Light: 100-114
Very light: 115-135
that looks awesome!, is that a tamper size so the grounds can be put in a filter basket?
LMWDP #483
Yes, it was designed for use with a filter basket... mine is a 54mm double shot basket, but it was made universal and should work for other basket sizes too. Another feature is that the sample can be tested using the unit itself, if someone doesn't want to use a filter basket for some reason. A minimum of about 6-7 grams would be required depending on the grind size. I'll be making a user video of it in the coming days...
Any progress on your scale?Brewzologist wrote:I'm going to create a draft scale for the DIY meter similar to what EspressoVision did for their meter.
