Cormorant Revisited - Page 2
I am really wondering how essential it is to use software with this roaster. (When Johan roasts in his clips he does not use Artisan...but makes adjustments to gas, fans intuitively).
- JohnB.
Pretty much everyone is roasting manually unless they convert the gas/fan controls. All my roasts are manual, I don't use artisan, ect. Just finished a 430g espresso roast of a nice Colombian Crown Jewel from Royal Coffee. I have 2mm thermocouples installed for BT & ET & I monitor temps with a Fluke temp meter. I don't use the stock analog gauge info as it lags WAY behind the digital probes.
LMWDP 267
Do you just alter the gas flow to achieve a desired rate of rise per minute for the duration of the roast? Or is there more involved than this?JohnB. wrote:Pretty much everyone is roasting manually unless they convert the gas/fan controls. All my roasts are manual, I don't use artisan, ect. Just finished a 430g espresso roast of a nice Colombian Crown Jewel from Royal Coffee. I have 2mm thermocouples installed for BT & ET & I monitor temps with a Fluke temp meter. I don't use the stock analog gauge info as it lags WAY behind the digital probes.
- JohnB.
Charge temp, gas flow & fan speed. Still figuring things out as this is my first gas roaster & I've only done 12 roasts with it so far. Fan speed is critical to getting a good ROR coming out of the drying period. Had the fan speed too low in my early roasts & even with full gas flow I wasn't seeing the ROR I wanted. Once I started playing with the fan speed more during one of my roasts I was able to see where it needed to be to get the ROR going early in the roast so the roast got to 1C in a reasonable amount of time & where I wanted it set approaching 1C to slow things down to get the development time I want for that roast.
LMWDP 267
Sorry, I'm a bit late coming in on this. I just added my name to the wait list for a March delivery. I've been using a Huky for about five years. Do the Cormorant thermocouples connect to a laptop through a Phidget 1048 like the Huky thermocouples?
- Chert
- JohnB.
They probably would but I'd suggest skipping the optional 5mm-6mm T/Cs that Johan supplies & pick up a pair of 2mm or 3mm thermocouples. Here in the U.S. many of us bought these: https://millcityroasters.com/product-ca ... es-gauges/thusband wrote:Sorry, I'm a bit late coming in on this. I just added my name to the wait list for a March delivery. I've been using a Huky for about five years. Do the Cormorant thermocouples connect to a laptop through a Phidget 1048 like the Huky thermocouples?
Johan's digital BT probe location works well but for ET you will want to drill the lower bean chute mounting bolt & install a 75mm probe as I described in my post on the Facebook Cormorant Group forum.
LMWDP 267
Thanks! You mention a 2 or 3mm probe from Mill City. Is that correct? Maybe the 75mm? I wonder if I could get Johan to drill that out? Also I can't seem to find the that Cormorant Facebook Group. Could you point me in the right direction?
Thanks again.
Thanks again.
Thanks, That's a real beauty. The powder coating is stunning.Chert wrote:You get a nice looking machine, slightly greater batch size.
I thought this image from the Cormorant pages clever:
<image>
