Cooling the roast and sweetness
- farmroast
The SCAA online resource library is now open to the public. I was checking out a panel discussion with Carl Staub called "How to obtain excellence with drum roasters" 2002. Carl mentions the importance of rapid cooling for the solubility of the sugars. It appears that if it's taking more than 4 mins to cool your roast you will be losing significant amounts of sweetness in the cup. It also effects the formation of espresso. Also interesting is the abilities of sugars passing through a paper filter.
This is the key statement from Carl Staub:
"We all look for sweetness in the cup and something we often ignore is how we cool the coffee after we
roast it. But, it is part of the process. I don't like water quenching, but I am a proponent of trying to cool the
coffee once it comes out of the roaster in four minutes or less. And why do I say that? We've done
experiments using exactly the same strategy cooling the coffee in six minutes, five minutes, and four
minutes. From six minutes to five minutes there is a small improvement in the sweetness of the coffee.
When you go from five minutes to four minutes, the sweetness in the cup doubles and there is a definite
chemical explanation for why that happens. This is due to sugar solubility. The primary sugar in coffee is
sucrose. During the roasting process you fracture the sucrose and you want to caramelize it or polymerize
it in the scientific term. But, you also have to maintain solubility. If it doesn't come out when you put water
into it, it is not going to be a sweet cup. Having the sugar there is one issue, being able to get it out with
hot water is another issue. If you cool it too slowly, the long series chain polymers, sugars, fructose and
glucose will find other constituents to link up with in the coffee and they are not as soluble.
Likewise, during the roasting process if you form molecules that are very large, they may be favorable for
espresso extraction you will get a lot of crema. Having the starches, oils, lipids, and fatty proteins in the
coffee is a very good thing for espresso. But, when you try to apply that same strategy to coffee that is
going through a paper filter, the water doesn't want to go through the filter. The larger molecules get
trapped by the paper filter and don't end up in the cup."
from SCAA Conference Transcript 2002 (Newall, Lee,Diedrich, Staub)
LMWDP #167 "with coffee we create with wine we celebrate"
I was just thinking about this. On the other side of the coin, is there any such thing as cooling to roast TOO fast? I go from 430F to room temperature in my roasts in less than a minute, but it seems most professional grade roasters are designed to go to room temperature in 2-4 minutes...
Dana Leighton
LMWDP #269
LMWDP #269
- farmroast (original poster)
Too fast(at the start) could cause fracturing and divots. Like when as kids we used to heat up crystal marbles and drop them in cold water
- JmanEspresso
What is the "standard" temp that coffee is considered "cooled". 235F? 300F? Room Temp?
- endlesscycles
That particular article defines cool as room temp. I'm curious what the internal temp lag is.
-Marshall Hance
Asheville, NC
Asheville, NC
You could try dumping your beans out of cooling into a container with a TC stuck into the mass or an IR thermometer might work. Unless I hear that something chemically good can happen with the beans being left slightly warm, I cool them right down to room temp.
- rama
Ed, thanks for sharing the link. The "How to obtain excellence with drum roasters" was a good find. Have you found any other worthwhile articles? A quick browse was a bit disappointing...
- yakster
Yes, Ed, thanks for the info here, very helpful. I started browsing the SCAA library last night and found a few nuggets. There's a corresponding talk "How to obtain excellence with fluid bed roasters" by Michael Sivetz from the 2002 SCAA conference available, though I haven't listened to the audio files yet: Audio Files; Handout; and Transcript.
The one presentation that I have listened to, however, is "More perspectives: roasting and blending for espresso--the world view: secrets of international experts" from the 2003 SCAA conference. The panel consists of Adalheidur Hedinsdottir from Kaffitar in Iceland, Sunalini N. Menon of Coffeelab in India, and Instaurator from Australia. This touches on blending, roasting, and cooling and one of the experts does mention that you double the sweetness by cooling the beans within four minutes but there is not that much difference between four minutes and three minutes. The abstract reads:
I've been having the most luck with using the Quick Links tab in the SCAA Resources library and browsing by subject or type (computer file).
Regarding cooling home-roasted beans within four minutes, I'm planning on modifying my cooling routine with the Behmor to dump the beans after one minute of cool cycle into my home-made been cooler (stainless steel steamer basket fitted to a plastic storage cylinder with a shop vac pulling air through the beans) that worked so well with the popcorn popper. We'll have to see how it holds up to the increased batch size with the Behmor, but I'm hoping for the best. I may even try dumping half a load into the external cooler so I can compare the two methods. I'm already opening the door and putting a mesh in front of the Behmor to catch the flying Chaff, but I'm still falling outside four minutes.
I found this panel very enjoyable and informative. No transcripts or handouts were available.Espresso takes on the flavor of the people who produce it. Seasoned roasters from Asia, Europe and the Americas will tell all and share geographical preferences, from roasting degree to sweetening the blends with secret origin ingredients.
-Chris
LMWDP # 272
LMWDP # 272
Thanks for the info.
I used to let the Behmor cooling cycle do its thing and always thought that my roasts were lacking something. I don't even remember why, but I started opening the door of the roaster after all 2nd cracks (if any) were completed to accelerate the cooling process. Anecdotally, I thought it improved my roast results. I've never checked to see how cool the beans are after 4 minutes, but I do know the roaster is cooler.
Michael
Michael
wabi sabi - nothing lasts, nothing is finished, and nothing is perfect
Regarding cooling using the Behmor, I have always just opened the front door wide open after I hit cool and put a two foot tall 3 speed floor fan on "3" (fastest) and blow for about 4 minutes and it seems to work fine (although I haven't verified how cool the beans get, the air comming out of the unit is substantially cooled so I'm assuming the beans are as well). Only a few chaff flakes are blown out doing this (but I have the old/full size chaff tray which helps). If 2C were really rolling I would wait until the pops subside a bit to avoid encouraging a fire w/ the fan but usually I don't go too far into it. Also, this is done in front of a fireplace so the smoke blows (in general) up the chimney.
Perhaps this is a dumb question, but if the majority of sugars in coffee are sucrose, then why would we care so much about preserving it (if its down...then just put some more sucrose...i.e., table sugar, into the cup?). Just a thought.
Pat
Pat
