Bypassing thermostat on popcorn popper
well, the round thing is a fuse, if it get's to hot the machine stops working, the other part is the thermostat. My first thought was to try and wrap a piece of 22 ga solid copper wire around the thermostat to keep it from opening. It's kind of crude, but really easy to try and might work just fine. Because of the way it's assembled, bypassing both those pieces might be tricky. If that works and the fuse opens, you will need to move the wire to the other side of the fuse. Maybe bend the fuse away from the hole so it stays cooler if that makes any sense.
Ira
Ira
Thanks, great idea to wrap a wire around the thermostat. I wasn't thinking that I'd need to bypass the fuse, thinking it wouldn't get hot enough to trip that but I guess I'll find out.
I hope it's a great idea, it might to turn out to be a stupid, but doing it the right way on that machine doesn't look fun. It's certainly not designed to be serviced.
Ira
Ira
As Ira wrote. I'm not equipped for a soldering job that supports high temp use, which AFAIK would require a torch and specialized solder.
