Behmor 2000AB Plus
randyr5
#1: Post by randyr5 »
I'm considering purchasing the new Behmor roaster. My question is - how does it perform in cold temps outdoors? Roasting indoors is not an option.
mkane
#2: Post by mkane »
I would venture to guess not very well.
Aida Battle: Indigo Reserve from world renowned Finca Kilimanjaro in El Salvador
Sponsored by Aida Battle
quality8453
#3: Post by quality8453 »
I have a 1600+ and roast outdoors. My electricity is 120V. I roast between high 60° and low 80°range. The Behmor doesn't do well when it gets colder than 65°F. It just doesn't have enough heating power to overcome a lower ambient temperature. If I am out of coffee, and the weather is cooler, like a couple of weeks ago, where we had days in the low-60°F range, I will buy professionally-roasted beans or even store-brewed coffee.
jpschust
Supporter
#4: Post by jpschust »
randyr5 wrote:I'm considering purchasing the new Behmor roaster. My question is - how does it perform in cold temps outdoors? Roasting indoors is not an option.
I guess the question is how cold? I've got the 2000ab and I find it performs extremely well down to about 40 or so degrees. Below that not only am I uncomfortable, the heat retention in the unit starts to suffer a bit. In some ways that can be great- with very sensitive greens it can extend some time in 1C or give you a bit of breathing room. When it gets really cold here in Chicago I'll move to using my garage instead.
Word_salad
#5: Post by Word_salad »
Well I have a 1600 plus and I've roasted outdoors through a Minnesota winter. While it's not the best I haven't had any trouble reaching FC in a reasonable amount of time. You can wrap the unit in towels and keep it off the ground to insulate a bit. Also a full preheat helps. I think the coldest I roasted was 9 degrees, really sucks to stand outside not moving around though.
jakubx80
#6: Post by jakubx80 »
Behmor is fairly easy to insulate. There is a gap underneath the top black housing panel and inner liner. It's really your biggest bang for the buck.
I haven't done it but if I was to do this I'd stay away from Alumina based ceramic insulation blankets and would choose something like that instead. Ceramic blankets can shed particles.
https://www.amazon.com/dp/B072N5WTF2/re ... 4Fb7YPK5MA
Alternatively you could put a reflective sheathing on the inside wall of the black panel so that it'll reflect back radiative energy.
★ Helpful
