Artisan or something wrong? - Page 2
- CarefreeBuzzBuzz
. I didn't look at that aspect. Yes something is wrong. Probes need to be tested but the person needs to put some effort into getting Artisan set up.Marcelnl wrote:Michael are you sure this is only a bit of flat roast?
I would simply start with do the probes report something near a correct ambient temp.
yeah boiling water is more for when the temp is off...I'm thinking the roaster may have PID temp control, not sure what type of roaster so a picture/description helps but indeed it all starts with reading the Artisan manual.
LMWDP #483
He said he use K type.littlenut wrote:If thermocouple, correct type?
He denied that Coffie was not 1C at about 190-200 ° c. The machine he produced made it pop as low as I shared the picture.
Right now, the real problem is the person building the machine or the machine. Or is there a setting where it goes wrong? I'm completely confused.
Thank you very much. This is probably the best way to look for the error.Marcelnl wrote: Did you check if there is an offset for temperature in Artisan ?
If not you should be able to take one temperature probe out of the roaster and put it in boiling water to check various artisan settings to find what is going wrong.
like this:
So it's a drum roaster, is it electrically heated? Can you tell us how you manage heat, do you set one and the same temperature using the PID controller?
What sort of fan is it using, how do you control air?
LMWDP #483
Ask Coffeemarta about his machine system.
