Hello folks. I've been toying with designer and mapped out a graph. I would like critique on the points chosen please.
Artisan designer
What kind of coffee is this for? What are you trying to get out of it? What is the batch size?
- drgary
Also the data points you've put in and your ability to meet them and get good results depend on the characteristics of your roaster.
Similar to you I am learning to use Artisan Designer and am finding I need to tune its programming to my roaster's characteristics and results in the cup.
LMWDP#308
LMWDP#308
- CarefreeBuzzBuzz
There is a video linked on the Quick Start Guide that may help with learning.
https://artisan-roasterscope.blogspot.c ... igner.html
- mkane (original poster)
Thanks for the replys folks. Bean is a DP Rwanda, 360g. Michael, I watched the video thanks. Something else to play with and if I can come up with a profile I can meet I would imagine it could only get better. I put together another profile and chased it until drop. This smell good, darker than I would go for myself but my wife likes it very dark.
Should I add some smoothing? thanks
- CarefreeBuzzBuzz
Another thing you can do now is run Analyzer and then switch profiles, and save that X2 curve created by the analysis to use as a background roast.
- CarefreeBuzzBuzz
You drag the smaller window. Artisan will remember it next time.mkane wrote:What do you make of this? Still very Greek to me. I can't make the small window go away to see what's underneath.
.21 MSE BT is ok. Try to lower it. Where ABC/sec are higher than one you have an issue to look at. During that interval you were consistently pretty far off the ideal curve.
