Thanks Marko. That makes sense. I will set it up as per your recommendation.
With the extra device setup I am still wondering why the ET temp thru the phidget control panel and the one showing in Artisan doesn't match.
Artisan and Phidget hub5000 and 2x TMP1100_0 - Page 2
Marko, one more thing. In Windows the extra devices drop down shows abbreviations. Ie I think I have to choose "Phidget...1xTC" but I can't be fully sure. It's not showing the TMP1100 part.MaKoMo wrote: Now choose tab "Extra Devices" in the same dialog and add one extra device and choose as device type again "TMP1100 1xTC" for your second module. You can untick LCD and curve for this devices 2nd channel as the TMP1100 will only return one signal. Untick also LCD and curve for the first channel of this extra device as we will remap it to the main devices ET channel and do not need to see this data twice.
- MaKoMo
I do not have a Windows machine to check. I will ask someone to investigate this for me.
Which type of probes do you have connected to your modules. All the same type? All k-type?
LMWDP #360, https://artisan-scope.org
- MaKoMo
Did you try to enlarge the first column by dragging its column header border to the left.
I apologise. I tried enlarging the column yesterday and it didn't work for me. But now it does - so yesterday I probably forgot to select the header in that column first.MaKoMo wrote:Did you try to enlarge the first column by dragging its column header border to the left.
All good now.
