Artisan 2.8 Released - Page 2
I'm a very newbie roaster and so also a newbie with Artisan Scope but I am really happy this software exists in the public domain and also very happy for the Quick Start guide.
I don't know if this is a 2.8 issue since I had not tried to put an offset in under the previous release, but when I add an offset to my symbolic assignment such as BT x-5 and then click on Update Profile, the BT and RoR graphs disappear. My event markers are still visible but no graph lines. I was under the impression I could apply an offset and then look at it for the current foreground profile. Am I missing something?
- MaKoMo
Most likely your symbolic formula is wrong and evaluates to an error for all readings. Did you use the wrong or the correct ?
BT x-5
x-5
LMWDP #360, https://artisan-scope.org
I used simply 'x-5' for the BT symbolic reference. I had played with entering offsets before without an issue, but I had never tried to use the Update Profile button on an existing profile until yesterday.
- zeece
You are offsetting BT for an already completed roast profile, so 'x' is the wrong symbol here. This requires using "Y2-5" for the equation then hit Update Profile. Y2 is the symbol for BT stored in a recorded profile. Y2 and x mean different things. See the help button on the Symb ET/BT tab.kennelcoffee wrote:I used simply 'x-5' for the BT symbolic reference. I had played with entering offsets before without an issue, but I had never tried to use the Update Profile button on an existing profile until yesterday.
Use "x-5" to offset when live recording. Here x is the symbol for the incoming raw temperature channel reading. It tells Artisan to adjust the live temperature before recording it in the profile. When you use "x-5" and then hit Update Profile, Artisan tries to subtract 5 from the incoming BT reading. The incoming BT is undefined so Artisan writes -1 for each BT temperature value.
Well now, that makes sense. I'm usually a strong proponent of RTFM, but the help wasn't triggering my brain until you brought it up. Going back and looking again, well duh. Thanks so much.
- Chert
I installed release 2.8. Thanks Artisan team. I look forward to roasting with the new features.
LMWDP #198
