32 bit Artisan
NuanceCoffee
#1: Post by NuanceCoffee »
Hi!
Where can I get the following file: "artisan-linux-1.1.0_i386.deb" ? It is not showing up under "assets" in Artisan's GitHub for version 1.1.0
I require this file for an old Asus 32-bit Netbook with Ubuntu 12.10 installed. I would be using this netbook as a dedicated pc for logging roast profiles on an Aillio Bullet (this company's proprietary RoasTime roast profiler has no software versions compatible with 32-bit Ubuntu systems).
I believe "artisan-linux-1.1.0_i386.deb" is the very last of 32-bit linux/Ubuntu based Artisan versions.
Also, where would I find associated driver files for the same?
Thanks! Ashish
Marcelnl
#2: Post by Marcelnl »
LMWDP #483
billsey
#3: Post by billsey »
You will likely have to build it from the source. Grab the tar.gz file...
