What does a blueish residue in espresso machine boiler indicate?
My Rancilio Silvia V2 recently started tripping my GFCI outlet, turns out I have a faulty heater (seeing about 3Mohms between terminals and boiler body).
Tonight I took the boiler out and noticed blue residue. Just curious if that is normal or what would cause it (I found one thread that suggests overheating).
Thanks
Thanks
- Jeff
I won't argue with your assessment of the cause of the problem, but 3 meg and even 240 V is only about 80 uA, less that a tenth of a mA.
Top 9 Causes Of Copper Corrosion Problems
- Low pH (acid water less than 7.0)
- High pH (alkaline water greater than 8.5)
- High levels of dissolved oxygen
- High levels of salts dissolved in the water (total dissolved solids)
- Corrosion-causing bacteria such as sulfate or iron bacteria
- Electrochemical causes, such as improper grounding of electrical appliances to the copper piping, and/or lightning strikes through utility poles grounding wires
- High velocity of water, relative to size of piping, causing hydraulic wear on the piping, sometimes found in circulating hot water systems using pumps
- Sand, sediment or other grit in the water causing hydraulic wear on the piping
- Improper installation of copper piping by failure to properly de-burr or ream the ends of the pipe and/or the use of excessive acid flux when soldering the pipes.
- slipchuck
Have you descaled it lately? The citric acid will turn the water blue when in contact with minerals etc
Randy
Randy
That is a very good point (Plus I am on 120V). The meter reading fluctuates quite a bit. Most consistently I get 3M, but I've seen it as low as 250K.Jeff wrote:I won't argue with your assessment of the cause of the problem, but 3 meg and even 240 V is only about 80 uA, less that a tenth of a mA.
FWIW, the heather would run for a few minutes before tripping. I am measuring the resistance with the boiler cold and out of the machine.
It's been sitting idle for over a year -- I *think* I had descaled it pretty recently before letting it sit.slipchuck wrote:Have you descaled it lately? The citric acid will turn the water blue when in contact with minerals etc
Randy
Forgot to attach a photo in the original post.
- homeburrero
Jeff's calculation is spot on, and even at 250 kiloOhm and 120V you would be looking at less than a milliAmp of current leakage to ground. But unless you used an insulation tester (aka megger) I would not put too much faith in that resistance reading.
The blue is certainly some form of copper salt, which indicates some corrosion of copper or copper alloy (like brass). This could be due to harsh and unnecessary descaling. Also may be due to chloride ion, especially when combined with low alkalinity water. It's interesting that whatever it is has deposited on the brass boiler walls and not on the copper element. I think the solution is to avoid descaling when not needed and avoid harsh strong acids if/when you do descale (use a descaling product per instructions) and rinse very well.
You should be OK in Seattle with respect to chloride ion. If you're using a standard Brita jug charcoal filter you might want to consider switching to the new Longlast filter. Unlike the standard filter, the Longlast should not reduce your water's alkalinity, which is already on the low side in Seattle. Seattle water is soft and should not require periodic descaling: Seattle water
The blue that you have there now can probably be scrubbed clean with a green scrubby. It might be informative to scrape some of the blue stuff into a cup and see if it dissolves after an hour or two in pure white vinegar. If it doesn't dissolve you have something other than carbonate, which typical descaling would not remove.
In the old days people generally believed in the idea of 'protective scale' that you would periodically remove with descaling. Nowadays you see a lot more advice that recommends non-scaling water with good alkalinity and avoiding the need to descale altogether.
Pat
