Used Astoria Argenta with missing pump
Hi guys.
Great site you have here.
I recently purchased an Astoria argenta single group coffee machine without a pump, the man I bought it from said it was like that when he purchased it and probably had an external pump.
My question is can I hook up any external pump that goes to 9 bar and run it that way or do I need the original pump, thanks.
Kind regards Denis.
If that fuzzy white blob is female plug, it might be the outlet for the pump. Otherwise, there are likely 2 or 3 wires that appear to be cut hiding behind the left panel. You can wire in any AC pump that matches the voltage specificaitons, but I'd recommend the rotary pump setup it came with. A vibratory pump will work and can be hidden inside the machine, but they're intrinsically loud and annoying because they vibrate all the metal parts, making them seem even more loud...
Thanks for the reply Scot, much appreciated.
That has made my mind up to go for a rotary pump, would it have been an external or internal one do you think.
If it's like mine, it's external. Yours may be different as I had the Laurentis (same manufacturer). A smaller pump could probably fit inside mine, but I already had the external setup. Below is a link which may be useful for helping you figure out your configuration.
http://www.cafeparts.com/Espresso-Machi ... tors-Pumps
The external pump setup is nice for the fact that it's usually under the countertop, thus very quiet - the solenoids opening and closing are the loudest part on mine.
External pump is it, thanks for the link Scott.
Hi Scott/Guys
I am having trouble finding a flow meter for my machine,(if it is meant to have one) it has what looks like a Giemme control panel.
I purchased a external pump as per your recommendations, thanks Scott.
In cafe parts the closest boiler is a Boiler boosted 1 Gruppie, so I think my coffee machine is an Astoria CMA Boiler boosted 1 Gruppie, would this be correct. as hard to get a manual for this model?
And would the date of manufacturer be 16/12/2010?
Many thanks again Denis.
Hi Denis,
The Giemme controls the auto-fill. Your machine doesn't have volumetric dosing, so there's no flow meter. The rocker switch on the front panel turns on the pump and activates the 3-way solenoid for brewing.
Thats good, that I dont need a flow meter, thanks Scott.
- erics
- Supporter ★
Maybe you should go here: /downloads/
