Toothbrush tools & dissolving steel from brass - tips for the rebuilder - Page 2
- Randy G.
This is the brusk I made to clean the Kony's chute. One end is a "scraper," its length is to allow it to clear the throat when the grinder is in operation (if done prudently). The brush reaches all the way into the grind chamber (when the grinder is stopped). Once cleared, a bump or two with the power switch and retention is near zero.
