Tool ideas for tight spots.
- redbone
Crow's foot wrench is another option, but the box spanner is probably the most affordable.
- Randy G.
I first thought that a thinwall deep socket gripped with locking pliers with a screwdriver through the socket. All you likely need to do is break loose the nut..
- BaristaBoy E61
Needle Nose Pliers?
pipe wrench with the screwdriver in it?
edit: basically what Paul said, different name for the same tool...
LMWDP #483
Thin wall deep socket. Do not need to deal with the terminal screw in most cases. Use a top quality penetrating oil such as KROIL as most other choices are best left on the shelf and allow it to penetrate over night. The deep socket must be broached deep enough to clear the terminal stud which is likely just screwed onto the element end.
- redbone (original poster)
Thanks for the suggestions.
Tried a box spanner but due to the offset I'm not able to place a anything tall as it hits the inside wall. Next attempt will be with a crows foot wrench. Tried a few needle nose pliers but unable to get the torque / grip required to loosen the nuts.
Notice Francesco made a tool similar to crow foot wrench to deal with the problem. http://www.francescoceccarelli.eu/Faida ... C_6546.JPG
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
- BaristaBoy E61
I was thinking more about an electrician's long nose pliers that would possibly provide the reach & torque necessary to get the job done.redbone wrote:Thanks for the suggestions. Tried a few needle nose pliers but unable to get the torque / grip required to loosen the nuts.
Buy an inexpensive deep socket and grand away what's in the way till you've made a custom tool for that part. At least that's what I would do.
If you get a 12 point socket you'll have less to grind away and it doesn't look like those nuts are likely very tight.
Ira
Ira
