redbone (original poster)
Posts: 3564 Joined: 12 years ago
#11 :
Post
by redbone (original poster) » May 24th, 2019, 2:46 pm
Just picked this up. Will give it a try when I get in from work.
Semper discens.
Rob
LMWDP #549
#12 :
Post
by redbone (original poster) » May 24th, 2019, 7:46 pm
Was able to get the 17" in but had to go in vertically. A little fiddling around and I managed to set it around the nut but vert little allowance for movement beyond breaking it loose. Used a long needle nose plier to unscrew the rest of the way.
Semper discens.
Rob
LMWDP #549
shotwell
Posts: 256 Joined: 5 years ago
#13 :
Post
by shotwell » May 24th, 2019, 8:26 pm
Glad that worked!
grog
Posts: 1807 Joined: 12 years ago
#14 :
Post
by grog » May 25th, 2019, 10:38 am
Will you be able to tighten back up on re-installation?
LMWDP #514
Freddy Camacho
Posts: 112 Joined: 6 years ago
#15 :
Post
by Freddy Camacho » May 25th, 2019, 11:18 am
What machine is that rob? Open boiler? Radaelli?
shotwell
#16 :
Post
by shotwell » May 25th, 2019, 11:39 am
There should be more clearance in the tightening direction, but the wrench can be ground down significantly to fit. A nicer crow's foot from Mac, SK, Proto or another premium tool maker can be sourced in 17mm and would likely fit in much tighter spaces.
#17 :
Post
by redbone (original poster) » May 25th, 2019, 2:21 pm
Freddy Camacho wrote: What machine is that rob? Open boiler? Radaelli?
Big reveal, you guessed it late 57 build with 58 serial number Radaelli CAFFOMATIC.
Doing a total strip down and element conversion.
Semper discens.
Rob
LMWDP #549
Freddy Camacho
#18 :
Post
by Freddy Camacho » May 25th, 2019, 2:30 pm
Was in a similar tight spot myself with my peppina
Thats is a beauty. Looks awesme!
#19 :
Post
by redbone (original poster) » May 25th, 2019, 3:38 pm
Back plate and toggle switch similar to but not exactly to the ones seen on early LP Europiccola.
Semper discens.
Rob
LMWDP #549
