TIP: cleaning shower screen
I soaked my shower screen in cafiza and then went at it with both a tooth brush and a hard bristle brush.
I got most of the surface gunk out but the coffee in the micron holes were tough.
So I used my pressure washer.
Because I can't hold the shower screen - dangerous. Can rip your fingers badly.
I set the shower screen in a generic to-go coffee shop cup.
Fortunately bottom of the disposable cup was exactly the size of my shower screen.
Then just power wash the shower screen in the cup.
I found that I got more power by turning the cup upside down and spraying up into it. This way the cup isnt filling with water and reducing the pressure effect.
Wonderful.
Wonderful.
you mean the Shower screen? Anyway, a pressure washer IMO is far too blunt of a tool for something as small as a filter basket or showerscreen.
If either needs cleaning I throw it in a small ultrasonic cleaner with some triphosphate cleaner (like Cafiza), ultrasonic cleaner should not cost much and do wonders on all sorts of small and delicate items.
LMWDP #483
Oh yeah, shower screen.
I was willing to risk to test.
Turns out fine.
Turns out fine.
Or, you could just get a puck screen from Flair or BPlus, and stop cleaning your shower screen whatsoever, because it is clean.
The machine still has to be back flushed once every few weeks or so, but otherwise it is maintenance free (mine is not E61, and the grouphead does not require lubrication).
With my IMS nano screen I've never needed anything more than a group head brush and very hot water. A couple of time I've soaked it in Jo Glo and it doesn't appear to get any cleaner. Largely its a non issue if you clean it every week or two.
- RapidCoffee
John
- baldheadracing
I do the same.Marcelnl wrote:...
Keeping in the "Tip" title of this thread, one tip I would have is for machines with groups that use mechanical moving parts like E-61's or lever machines. In a new machine or a machine that has just been maintained/lubricated, the grease used can make its way down to the shower screen and - especially with silicone lubricants - the grease will collect on the screen. I will clean the screen much more often in these situations.
I just put mine in the dishwasher. Comes out clean every time.
