Thread Sealant... Again - Page 2
- JohnB.
It's written on the back of every can. "Service temperature of -15°F to 350°F"cafeIKE wrote:Where is that information?
World wide I couldn't find a document for RS that lists 350°F for other than flash point
Found this on a resellers site:
Multi-Purpose Pipe Thread Sealant, Series/Model: No.5, Size: 8 OZ, Container Type: Can, Yellow Color, Form: Paste, Odor: Mild, Temperature Rating: -50 To 400 DEG F, Brushable: 20 - 140 DEG F, Specific Gravity: 1.38, Flash Point: 150 DEG F, VOC: 230 G/L, Industry Standards: Certified To NSF/ANSI 61-G And 372, UPC File Number 1282 Listed, CSA/US Listed, UL Classified, ULC Listed MH12259, Federal Specification TT-S-1732, Additional Specifications: Pressure Rating: 12000 PSI At Liquid, 2600 PSI Gases, Shelf Life: 2 YR, Boiling Point: 322 DEG F
LMWDP 267
- stefano65
- Sponsor
We are using the loxeal brand and there are several option and applications
http://www.loxeal.com/en/
Stefano Cremonesi
Stefano's Espresso Care
Repairs & sales from Oregon.
- cafeIKE
- Supporter ❤
I'm not trying to be difficult, but does it specify potable water service temperature range?JohnB. wrote:It's written on the back of every can. "Service temperature of -15°F to 350°F"
Unless it's at least 250°F, it probably should not be used on an espresso machine.
Many industrial chemicals have a maximum permissible level of a few parts per BILLION and some have NONE.
Ian's Coffee Stuff
Asking the question is almost as easy as looking up the answer
https://rectorseal.com/rectorseal-no-5-group/
Given the extremely tiny amount used, the surface area exposed and the lack of signifcant flow at the location where it is used I'd not worry anymore than when using PTFE tape (Teflon is no saint either)
LMWDP #483
- JohnB.
You?? Difficult?cafeIKE wrote:I'm not trying to be difficult, but does it specify potable water service temperature range?
LMWDP 267
rectorseal is the correct sealant for house water systems; suggest loctite 55 pipe sealing cord on espresso machines
Hi Camino,
I'm very interested in understanding what you learned from CC that indicated the boiler issue was tripping your GFCI. I have a La Marzocco that just started tripping my GFCI, this was after a move, and I'm trying to figure out where to start the troubleshooting.
Thanks,
Art
Thanks,
Art
- cafeIKE
- Supporter ❤
A GFCI trips when there is a small current in the earth safety. It can be caused by water in a connector, bad heating element, leaky motor, a moist salt path.
Over current load.
GFCI also go bad.
Over current load.
GFCI also go bad.
Ian's Coffee Stuff
