Technical drawing or dimensions of the E61 group or similar
Hello everybody,
At the moment I am planning my own espresso machine, which is mainly made of laser-cut and bent stainless steel sheets in 4 mm and 2 mm.
I am designing the brewing group and have measured my Lelit Pl92t as well as possible, but due to the limited space around it, I am not very confident with the dimensions. As it is important to have the correct gasket size in the 0.5 mm range, I am interested in a drawing of the E61 group or a .*stl file from which I could measure the dimensions.
In addition to the drawn dimensions I am interested in the "thread pitch" of the group.
My plan at the moment is to make a long slit with the laser, so that I can bend the rod up and weld it.
Would be nice if someone could help
