Should I replace this boiler? Rancilio Silvia
Wow! To my eye, that looks fine! Years ago I cleaned out a Gaggia classic aluminum boiler that was way way worse than that (even had to reface it)... still works great as my at-work machine.. and the satisfaction of saving it lasts, too. Yours hardly needs even a cleaning!
Have fun-
S
Have fun-
S
Good morning, Sunshine!
If it hasn't been frozen and warped or something, there's no reason to replace it. Why, it looks fine, what's wrong with it?
Heh, I'm new to this stuff so I just thought it looked a little dirty
I'll just give it a wash and put it back together.
Some is mineral that came in with the water, some is dust that settled in the reservoir, it'll wash/wipe away easily. A fingernail would scrape off the larger protrusions of calcium on the wall, then a steel bristled brush would clean it down to the brass in a couple minutes... Then one more washing and wipe clean so you're not introducing the loosened stuff to the descaling solution, then block off the ports and fill it with descaler to get even the nooks and crannies clean, if you want to go that far. Might as well while it's out there in your hands and easy.
Great, thank you very much.
I'll give it some elbow grease this week and see how it turns out.
Got any tips for getting rid of gunk/stuff left by/around the old boiler gasket?
Well I was going to let this project rest a couple of days but my obsessive nature got the better of me.
Gave the boiler and base a good do over with some fine steel wool and I'm pretty pleased with the results, not perfect but good enough.
Before:
After:
Previous owner used it a couple of times a day for about ten years, hope I can use it for at least that long still.
Before:
After:
- Jeff
All shiny!
Don't worry about the dark patina it will gather. Those oxides will help reduce potential corrosion and leaching.
I'll try to not be too anal about cleaning it after I put it back together. And maybe give it another look in ten years time
-assuming this thing doesn't rocket moowards the second I plug it back in.
