Found: grind timer, now looking for advice cutting a slot into the Major
As we are planning a new house (and Kitchen ) I am looking for a replacement for the 80ies darkroom timer I am currently using with my Mazzer Major, modified with the Wong chute and SSP burrs. Ideally I am looking for the smallest box possible, so it can be stuck to the side of the grinder so I can drill some holes to hide all the wiring.
long ago I found the (pretty expensive for what it does) Auberins timer but that sat in a clunky case. Is anyone aware of a nice solution, if need be I can cook up a relay with delay timer circuit myself but was hoping there is a ready made decent solution for this already.
found this: https://www.instructables.com/The-7-Cof ... der-Timer/
But would prefer a ready solution, no need for a display if setting the timer works in an easy way and the set time is repeatable and consistent.
LMWDP #483
I think I found what I was looking for, a 230V timer relay module, cost about a tenner
LMWDP #483
LMWDP #483
So the next stage will be to cut a slot in the Major case, the timer is approx 70*40mm and I'm thinking to install it where the PF support used to be installed.
From what I can see from the outside the thickness of the flat aluminum front is approx. 3-4mm, so I guess there are a few options to make a nice cutout...dremel with 32mm disc-probably tedious, a 110mm angle grinder-probably too large, drilling holes and sawing followed by filing-tedious and sloppy unless a lot of filing is involved versus a jigsaw loaded with a saw blade for metal-probably difficult to guide.
Anyone with tips or ideas?
LMWDP #483
Stick your display in a project box, and figure out how to mount the project box to your Major?
Won't look as nice, but you won't have to make a big hole in your grinder.
If you make a hole, one thing is the display seems to have a fairly wide bezel, which would hide some amount of slop.
I'd probably try to use a dremel with a bit that will cut metal. Carbide should work I think. And then figure out how to make a guide.
But I'm not sure exactly what the surface looks like that you're trying to cut, and I'm far from an expert here.
Randy
Randy
The whole idea is to replace the 80-ies darkroom timer I'm using for a non-external box solution.
Dremel I'll try, I have metal cutting discs hat should work on the Aluminum of the Mazzer. I hear you on the bezel, I'm afraid the timer does not have much bezel to offer but there always is Sikaflex...
LMWDP #483
I was thinking about this type of bit
https://us.dremel.com/en_US/products/-/ ... ide-cutter
Not sure if this is better than a disc, it can be hard to control a bit like the one above to get a straight line, why I'd try to use a holder and guide to get a straight line. Or maybe a jig saw.
Maybe a combination of these?
It would be better to use the Dremel to get close to your cut lines and then hand file to fit. You'll have better control with filing.
- Robert
