Screening out fines with a vibratory shell polisher?
Any one using a machine to shake out fines? I was thinking about making a fine mesh insert for a polisher i have to repurpose it and using #120 ss mesh screen. Waste of time?
I once made a powered sifter for one of those hand shaken sifter stacks. I attached a 8" woofer to a piece of plywood, made a hole the correct size for the bottom and a Rube Goldberg way to hold it in place, drove it with a couple of FETs driven by a Arduino, unbalanced square wave to give the coffee time to fall and a rubber glove across he bottom to keep coffee out of the speaker. It was a prototype for a commercial product that went nowhere. But, when I showed it to the person who I made it for, he was blown away by how fast it sifted, something like 10 times faster than the vibratory ones.
A bit noisy though.
Unless you want to sift a pound of coffee at a time, a vibratory polisher seems quite overkill. Unless you make a small weighted(to stay upright) container that just floats around in the media.
Ira
A bit noisy though.
Ira
- HB
- Admin
What kind of coffee preparation would benefit? Pourover? For what it's worth, here's a few other threads asking a related question:Chuck12345 wrote:Any one using a machine to shake out fines? ...Waste of time?
Thank you...I love the amount of thought you put in to that set up. I'm a tinkerer too and will probably try it for my brother...he uses a blade grinder or store bought for his esspresso/Americanos, and laughs at me using a scale. It is for about a lb.at a time.(i don't want to have to shake that much). I dont see doing it for my single dose but hey, might be fun.(coffee dust wafting thru the kitchen)
No, you need rubber diaphragms top and bottom. I've no actual idea whether what I did was advantageous. Partly it made it possible to make really interesting noises while it was working to make people think it was somehow special. I can tell you that it worked really well except it couldn't get the coffee off the edges of the screens. If I'd ever done a version 2, I would have built something to tap it to knock that stuff loose. Won't be a problem in what you're doing. The shaker I used was only about 2" in diameter.
Ira
Ira
Great... Now all those other VDT ideas have me thinking of vibrating the accupuncture needles in a hand held distribution tool. For esspresso...now off to the love shop
Vibrating the basket to distribute the puck has been tried a number of times and tends to end up a failure, maybe vibrating the distribution tool will work better.
