Scale Repair
goalerjones
Postby goalerjones » Jan 12, 2019, 7:49 pm
I bought the overpriced Decent Espresso basic scale (for $30 before I knew it was a cheap Chinese product). Now the double-sided tape that holds the actual weighing platform in place has failed and the platform is unsecured.
What would you recommend I use to secure the platform with?
I've tried normal double-sided tape but it failed to stick onto the surfaces.
Thanks
Espresso_Junky
Postby Espresso_Junky » Jan 12, 2019, 8:13 pm
How about a bit of hot glue? I use very strong 3M double sided tape most of the time around the house. It has insane holding power if it sticks to the surface good enough, but there are a few items that it was useless on, so out comes the hot glue provided the heat won't affect it negatively.
cafemolino
Postby cafemolino » Jan 12, 2019, 8:46 pm
Espresso_Junky wrote:
Seems everything Decent offers is Chinese garbage.
hope that the DE machines are not like that
goalerjones
Postby goalerjones » Jan 13, 2019, 6:55 pm
Espresso_Junky wrote:How about a bit of hot glue? I use very strong 3M double sided tape most of the time around the house. It has insane holding power if it sticks to the surface good enough, but there are a few items that it was useless on, so out comes the hot glue provided the heat won't affect it negatively.
Thanks, I will try the tape then hot glue...my wife has a HGG.
