Sage Smart Grinder Pro Not Grinding
Hi everyone,
I recently have got a used sage smart grinder pro but it has a problem that i may need some advice to diagnose.
Everything come live when powered up but when i insert the portafilter grinder does not run through timer countdowns as it is running?
Any advice on how to diagnose or where to look or check to sort it out would be highly appreciated.
Thanks,
Ugur
Thanks,
Ugur
Timer starts when I press start/pause button. But no sound no grinding.
I am sure it is not jammed as there is no sound at all.
If it is jammed, you will have no sound.... Did you try increasing gring size (by 10 points to be sure) and pressing again, to help if a bean locks the burrs? Pretty classic situation.
Unfortunately, result is same. I changed it with increment of 10, 20 even but still no sound not even a start click.
Would it be a thermal fuse on the motor itself, if there is any?
Thanks,
Ugur
Thanks,
Ugur
If it is the inner burr yes it does not rotate at all but I checked with my sage barista pro's grinder and the inmer burr on does not rotate either.
