Rocket Mozzafiato Type V - Pressure issue - Page 2
fhailywalid (original poster)
#11: Post by fhailywalid (original poster) »
I descaled the Machine 4 months ago, but somehow it wasn\'t enough for the Valve.( i use Brita filter for the water)
what is a mild descale :)?, for me there is descale or No descale!
JRising
#12: Post by JRising »
I am one of those people who try to avoid descaling, preferring to try to give the machines only good softened water. When I suspect that calcium might have deposited somewhere I like to mix up some descaler (On my own Giottos I usually use Urnex Dezcal) and mix it at 1/4 the strength that the package suggests. At work I use Skale Kleen at approximately 1/4 the suggested strength. Running this mild solution through doesn't give the machine much galvanic potential so I believe it's not stressing the dis-similar metals while it will still have a chemical reaction with the calcium and will come out cloudy if there's enough calcium in the crevices...
Then I have to decide whether I want to do a full strength descaling simply pumped through the circuit that needs it, or if I want to disassemble some parts and attack the individual deposits in a specific valve or at a restrictor in the thermosiphon loop or whatever the issue is.
#13: Post by fhailywalid (original poster) »
i will soft descale it on the weekend and see what will go out :)
#14: Post by fhailywalid (original poster) »
update:
Everything work perfectly after i cleaner the Valve, i did a soft descale as you recommended but wat did came out was really minimal.
thank you again for your help.
JRising
#15: Post by JRising »
I especially love that dosing cup, but all of the wooden accessories are gorgeous... Hide that red knock box. :D
