Rocket Giotto Evo R: Two manifolds cracked within a few months
I have my Rocket Giotto Evo R for about 3 years now. I really like the machine, simple to operate and effective. Not hard to repair either.
The machine is plumbed since the beginning. I only use the reservoir to decalc it every few months (the water is soft around here, so this is not a big issue).
However, right during Christmas, I did notice that the manifold cracked into pieces (see attached photos). I ordered a few one, I replaced it, and everything was good to go and operating normally. Notice that both the manifold *and* the fitting on the reservoir cracked.
First exploded manifold:
However, preparing for the next decalc, I noticed that it cracked again, which requires another replacement... The only difference between the two episodes is that I didn't leave the reservoir in the second time (I was fearing that it could put too much pressure and led to the manifold to explode the first time.
Second cracked manifold:
I am wondering the following:
From the second cracked manifold, we can clearly see it started in the bottom hole, but I don't sense any undue tension on that part of the manifold, the connecting tube is very slack.
Any advice or thoughts on that would be greatly appreciated!
- Is this simply something that happens often?
Is it because there should always be water in the thank & in the manifold, otherwise it dries out and cracks?
