Rocket Cellini heating element replacement
mattsnowboard
#1: Post by mattsnowboard »
I just inherited a broken Rocket Cellini espresso machine (and have no idea how to use it or do anything haha). It was tripping the GFCI so I found that I needed to replace the heating element. I got a replacement one, and after some percussive maintenance, managed to knock the old one out (confirming it was all corroded and melted).
My question is, should I just get the new one installed, or should I clean anything out before wrenching the new HE and gasket on? I assume I can just put it back together and follow normal cleaning steps to flush things out. But based on how the old HE looked it seems like maybe I should clean something while I have it open (if that's even possible).
Also, is there something I need to do when I put it back together to fill the boiler before the heating element turns on so it doesn't heat up dry?
Any tips are appreciated!
cafeIKE
Supporter ★
#2: Post by cafeIKE »
Clean it first.
Reassemble machine.
Leave heating element disconnected.
Fill with water.
Verify no leaks under pump pressure
Connect heating element... [hope all goes well]
Have fun!
Versalab: maker and supplier of finest espresso equipment
Sponsored by Versalab
mattsnowboard (original poster)
#3: Post by mattsnowboard (original poster) »
Thanks, any tips for cleaning it then?
Since it's pretty heavy, it's kind of a pain to move around a lot. But I guess I was thinking I could try putting it on the side with the heating element hole up, filling with water and dumping it out a few times.
I could try to find a brush or something to fit in there, not sure if it's worth going through that trouble.
cafeIKE
Supporter ★
#4: Post by cafeIKE »
you can take the boiler and everything apart and soak in bucket of citric acid solution.
This [urlhttps://www.home-barista.com/forums/search.php? ... t=0&ch=300]search [/url]will get you started
