Rocket Appartamento not maintaining steam pressure - Page 3
Well I swapped out the control board a few days ago and it's been working perfectly, so looks like that was the issue! Thanks for the help!
Might do the mod in a bit when I feel like reopening the machine.
- JohnB.
The relays in those boxes are inexpensive & easy to replace once the board is out of the housing. Get the part number off of the relay cover, get one online & have your friend replace it so you have a spare controller.
LMWDP 267
So I've removed the thin wires.
Safety thermostat to common on the p-stat.
Normally closed on the p stat back to the power board?
New power board already has jumper in place.
Additionally, I was told I needed to change my p stat for a 16a one. I assume I can use the old one until it breaks then change it for the new 16a one?
Your wiring looks good to me.
Your new p-stat is a 16amp.
Good job, enjoy your coffee.
