Roaster Automation - Drum Roaster
- Supporter ❤
Hi all,
I've looked at this thread Huky Gas Automation and tried to see I could use it with my BC 5 roaster. However, the Python code is from a different version, and after updating it, I can't seem to have my Python code talk to the Arduino board. Any help would be great.
When running the "arduinoCommunicator.py" file I see this message:
Arduino Uno (COM5) found at COM5
Pipe open for data from Artisan...
Then I run the "artisanprog.py GAS 50" to set the gas to 50 to check that Arduino sees the message; however, it gets stuck with
Sending data to arduino...
and I never receive the "Data sent" message
- Supporter ❤
- Supporter ❤
it appears that the call command for the python file does not seem to work as nothing happens when I push that button. Any suggestions?
- Supporter ❤
Thank you to @Brewzologist, who helped me troubleshoot the code. I needed to downgrade Python to 2.7 so that the code works.
I'll report as I make progress in the next few weeks.
- Supporter ❤
I have a question about sliders in Artisan: I use the Python routine to send button commands to the Arduino board where I specify the value; see my screenshot above. How could I use the sliders portion to do a similar thing? Meaning, as I move the slider, a new value to be passed to the Python routine?
- Supporter ❤
- Jeff
I'm not sure what all the lines are, but I would check the raw data for evidence of noise, either introduced or quantization. If a data series is "sticky" compared to the differencing interval, it would show "0" delta and then a large magnitude value as it stepped up/down to the next sticky value.
If https://github.com/phil-nelson/hukyroas ... nicator.py is the source, that shouldn't be too hard to port to Python 3 -- \'print\' is a function rather than a keyword and you probably have to convert to/from bytes rather than strings.
- Supporter ❤
Thank you, Jeff.
The source is from the Huky Gas Automation blog listed in the first post, and I tried porting to Python 3 but could not make it work. I ended up using Python 2.7, and that worked and I could create buttons and sliders, and I could manually open and close the gas valve.
I also checked the thermocouple noise and is fairly stable. It does appear that the data series is sticky; however, I don't know how to "unstick" it.
- Supporter ❤
My temperature readings in Artisan seem to lag behind the roaster's OMRON readings for ET and BT and get an update once every few seconds; I'm connected via Bluetooth. I don't know if that is an issue.Jeff wrote:I'm not sure what all the lines are, but I would check the raw data for evidence of noise, either introduced or quantization. If a data series is "sticky" compared to the differencing interval, it would show "0" delta and then a large magnitude value as it stepped up/down to the next sticky value.
- CarefreeBuzzBuzz
I recall in some discussion that Bluetooth is slower. You might want to ask this on the GitHub Discussion site.
