Replacement bulb for Lady Duchessa.
- cuppajoe
Greetings -
I am hoping someone out there knows the replacement bulb spec for the Lady Duchessa status lamp. It was AWOL when the machine arrived. The machine runs on 220V and the base a possible E14, but not sure. Looks like it takes a bulb about the size of a flashlight bulb.
Have been scouring the web and ebay, but hard the tell what's appropriate. Not much mini 220 stuff in the US. Francesco gave dimensions of 9mm X 28mm, which I guess is the globe only.
Thanks
Thanks
David - LMWDP 448
- zeb
Hey! e14 (14mm OD) is what I am looking for too for the Zenith Express I'm finishing. If I find something in France I'll let you know
Edit: Seems that if the inside diameter of the socket screw is 9mm your bulb is e10, not e14. I can order one e10 220v for you while I order my e14. Do you want ? Mp if in case
- cuppajoe (original poster)
Hi Pascal -
Thanks for confirming the base size. I found a couple of contenders on ebay, including a neon. If any work out I will let you know. I did find several 220V E14 miniature lamps on ebay as well. If I strike out I'll take you up on your offer.
Thanks
Thanks
David - LMWDP 448
- zeb
Read well David I don't confirm I was mostly asking confirmation myself
I was going on the premiss that if E14 meant a 14mm base, then E10 being the designation for a 9mm base sounded reasonable. In any case the E10 bulbs I ordered should be here in a couple of days. Hopefully they fit, as I was not seeing E14 in the size I needed.
David - LMWDP 448
Just got the E10 bulbs in and they fit the Duchessa perfectly. A bit bright, but not blinding. Osram E10 base and 28mm long.
David - LMWDP 448
- drgary
Thanks, David, for that good reference if any of us in the Duchessa club are ever in need.
LMWDP#308
LMWDP#308
