Replacement Boiler Ring/ Clamp - La Pavoni P/TRE?
Hi all,
Can anyone help me source a replacement boiler ring / clamp for a La Pavoni P/TRE (see photos)--or something that will work? I picked up a 2-group machine cheap and finally pulled and opened the boiler. The cast aluminum ring / clamp is corroded and broken with several seized bolts (boiler was leaking at the break).
I've reached out to two parts vendors and searched eBay, too. I found an old thread La Pavoni P/TRE restoration[/url] from a user with the same problem, but its not clear if they found a replacement. Good news is the heat exchanger is intact and the boiler isn't too bad.
Thanks for your help!
