Repairing old Faema Faemina
Faema
#1: Post by Faema »
Hello everyone! My first post here :)
I've got an old Faema espresso machine. (The label reads : Faema Faemina, Milano, Officine) (Another label reads: Venturo and Made in Italy and gives #14196, Volt 110, P - empty, and W- 1000).
I have not owned any espresso machines before, and I want to start now.
This one might be made out of copper, I am not sure. It has an European plug and needs rewiring.
I am not sure where can I repair / rewire it. It looks like it has not been used for a very long time, maybe ten years or more.
I am also not sure if I will be able to use it at all/ if it is reparable and how to use it. Where do I fill the water for example, etc?
Thank you for your help!!
Faema
wsfarrell
#2: Post by wsfarrell »
If you use this site's search function and look for "faemina rebuild," you'll get lots of hits, like this one by the legendary Vakse Viggo:
Faema Faemina rebuild
Good luck!
Beaniac
#3: Post by Beaniac »
summer
#4: Post by summer »
grog
#5: Post by grog »
Here's another gold standard resto to read through:
Faema Faemina Risurrezione!
LMWDP #514
redbone
#6: Post by redbone »
That F.F. looks like it spent some time either submerged or in a very damp environment judging by its condition.
Two ways to go about this :
1) Repair whereby you do some cosmetic cleanup but do a full rewire, seal \ gasket replacement and full interior cleaning and polishing.
2) Full refurbish including re-chroming outer boiler, boiler wrap, PF, lid and lever.
The difference in price is substantial since re-chroming or similar is expensive but yields the best results.
The links above are great. I would recommend a specialized tool to remove the piston sleeve. Found here at bottom right of page. http://www.francescoceccarelli.eu/Faidate/diy-faema.htm
A worthy effort for any espresso fan.
The F.Faemina spring lever with its innate brew profile makes for an excellent repeatable espresso.
Semper discens.
Rob
LMWDP #549
yakster
#7: Post by yakster »
redbone wrote:I would recommend a specialized tool to remove the piston sleeve. Found here at bottom right of page. http://www.francescoceccarelli.eu/Faidate/diy-faema.htm
When I checked in June, it wasn't available and I'd been meaning to make one using PVC and some rods, but thanks to you I just pulled the trigger on the sleeve tool on Francesco's site (along with more gaskets) so I can rebuild my Faemina which started leaking out the top of the group where the shaft exits the group.
-Chris
LMWDP # 272
redbone
#8: Post by redbone replying to yakster »
Excellent, glad I could help and good to have supporters of the F.Faemina.
Semper discens.
Rob
LMWDP #549
