Quickmill Andreja Premium. Lots of water flows back to reservoir?
Hi and good morning. I have a question regarding my Andreja Premium. After some cleaning and maintenance i realized, when raising the lever, with no blindfilter or anything attached, quite a lot of water flows back to the reservoir via the second hose (from T-Connection). In steady flow, seems to be about the same amount and flow as from group head. I do not think this is normal? And I do not really like the idea of circulating water.. I am aware of that some amount of water should/could flow back when using a blindfilter or when brewing. However, pressure reads fine about 9.5 with blindfilter and pressostat toggles between 1.1 and 1.4.
Any adjustment/repair/switching parts suggestions? OPV?
Thanks
/ jeppegross
Thanks
/ jeppegross
Assuming the second hose is coming from just pass the vibe pump, it's the pressure relief and it's supposed to do that.
If the flow and pressure over the prep are good and it's making a good espresso, it might be just fine...
How much is "Lots"?
How much is "Lots"?
Yes it might as well be
But my concerns are the amount of water and the circulation back to water reservoir, it is a steady flow when lever is raised all through the brewing process. For 1 cup of espresso I get 2 cups of water:
For now I have the ¨bypass hose¨going to a separate bowl and not back to the reservoir. If clamping the bypass hose pressure raises.
Well, if the OPV is passing water at less than where you want the maximum to be, then you can try to adjust the OPV to a higher setting. If it still passes water at a lower pressure than where you want it, then it's probably time to clean the OPV thoroughly and replace the valve-face. (I think the Andreja's valve face is just one of the common 8F194V viton valve faces common to several valves.
https://www.chriscoffee.com/products/ex ... ement-seat
Hi- I had the same problem on my A. P. The OPV valve seat was old and bad. I sanded it down as a temporary (successful) fix, and ordered a new seat. It helps a lot. I got the part at Chris Coffee: Quick Mill Expansion Valve Seat × 1
(But haven't installed the new one yet!)
Shuka
Shuka
Good morning, Sunshine!
