Snoroqc
#1 :
Post
by Snoroqc » February 20th, 2021, 2:30 pm
I have a leak under the profitec pro 700. The T is desintegrated. May be IDC can send me the part, May i find it elsewhere ?
Auctor
#2 :
Post
by Auctor » February 20th, 2021, 2:40 pm
If you don't mind me asking, does the component that disintegrated connect to the steam boiler? If so, at what temp you keep your steam boiler?
GC1
#3 :
Post
by GC1 » February 20th, 2021, 2:51 pm
Same thing occurred with with my Profitec Pro 700-it's a common point of failure.
WLL sent a new Tee Connector and 8mm silicone tubing. About $15 all together.
Snoroqc (original poster)
#4 :
Post
by Snoroqc (original poster) » February 20th, 2021, 3:09 pm
Yes it connect to steam boiler. The temp is set to 253 wich is within recommandations.
#5 :
Post
by Snoroqc (original poster) » February 20th, 2021, 7:11 pm
I found a t at the car department at a Canadian Tire. Lucky me. Profitec up and running.
physh
#6 :
Post
by physh » February 20th, 2021, 7:35 pm
I'd be concerned about lead or other contaminants.
#7 :
Post
by Snoroqc (original poster) » February 20th, 2021, 9:14 pm
Nope. One way out to the discharge nozzle. Then to the drip tray.
kitt
#8 :
Post
by kitt » February 20th, 2021, 10:50 pm
It usually disintegrates due to heat when the antivac valve fails, best to change that also, otherwise your just fixing the symptom ,not the cause
#9 :
Post
by Snoroqc (original poster) » replying to kitt » February 21st, 2021, 8:51 pm
Yes thank for pointing that. The brew boiler is leaking too at the refill elbow. Times for an overhaul.
#10 :
Post
by Snoroqc (original poster) » February 22nd, 2021, 10:02 am
The machine is leaking from temp probe and Elbow (red zone).
According to the parts diagram, the seal is made with copper seal for the elbow.
I have Loctite 567 High Temperature Thread Sealant
Any recommandation ?
