Prevent threaded connectors from leaking - Page 3
cafeIke.. thanks for your feedback. Re: the Loctite..this is what SCG specifically stated that Rocket uses. I asked several times.
I was able to get the fittings with crush washers on the boiler. I saw another post from Stefano and he uses angle iron to bolt to the boiler. So bought steel angle iron, drilled two holes that matched up with the two bosses welded to the boiler and was able to then clamp that assembly in a vice. This gave me enough stability to place required torque on the fittings.
