Pasquini Livia 90S with dead control module (Fixed) - Page 3
- hankbates
Just because Pasquini lists an item as sold out, it doesn't necessarily mean that it is no longer available. that spacer was probably made by Bezzera to allow them to use the new group on their older machines, and they also still have a bunch of them out there (BZ99, etc) just like Pasquini does. You might want to call Pasquini and ask, if you haven't already done so, when they will be back in stock?
Pretty simple part to make too...
Yes. Calling them is the plan. That raised rim on the new group can also be trimmed off on a lathe, plus as you say, the disc "could" be made. At the moment the plan is to replace the worn out PF, and install a silcone gasket in either 8 or 8.5mm, both of which have a flat face where the PF seals, vs. the ramped face that the OEM gasket has. If that cures the problem, I'll leave it as-is, because it will be plenty good enough for an occasional shot here at home.
I'm waiting for a few parts from Pasquini, but otherwise, the machine is up and running, and works great. It's a lot of fun to use, and I love the size of it.
- Chert
Thanks for sharing your rebuild - I really like the Livia 90. I have a very nice badged portafilter that needs a home (DM me if interested). I repaired and sold one of these a while back.austinado16 wrote:image
I stumbled across what appeared to be a nice, one-owner, 90S a couple weeks ago. It was being sold because it no longer controlled it's pressure, and an attempt at repair, had failed. It's arrived and I'm looking forward to learning about it, repairing it, and of course, making some espresso. While waiting for it to arrive, I found a non-working Salvatore "Italia" SES grinder that I think will look nice along side the Livia. I laughed when it arrived, because it's literally the guts of an ASCASO 54mm flat burrs grinder that this guy (a boutique shop in the tourist community of Solvang, CA) has very crudely "reboxed" into an internal fame of his own making, and a stainless metal skin that he bends up.
LMWDP #198
suggestion: Taste n Learn: turbo shots, light roast edition.
- hankbates
I did a search for the spacer by part number but couldn't find anyone having it in stock.
I did, however, find this BZ99 group, which should be what you need, in England.....
https://www.espressounderground.co.uk/B ... 002010.htm
When I put my Livia 90 together about 5 years ago I was able to get a new bell and a new portafilter from Pasquini at that time.
Really happy that I did.
Recently found a virtually unused L90 auto (touchpad control) near me for little money and gave it to my daughter. I would love to find a parts machine to be able to convert it to a brew switch unit like mine (and also yours).
Thanks gentlemen.
Hankbates: I just emailed espresso-underground, and asked them if their bell is flat on top, if they'll ship to the US. I have a friend in London, if they don't. If it's flat, I'll definitely buy it, because I would actually like for this machine to be "really nice" when I'm done with it.
Flint: thanks for the offer on the PF. At the moment, I'm thinking that I'd like to have a traditional looking one that just has the round, stepped, black handle. I've seen the ergonomic shaped one on the Pasquini site, that has the badge on it, but I think I like the old school version better.
I wonder if Pasquini sells a brew switch, and if so, if you could easily convert yours, just buy changing the wiring a little, and removing the flow sensor unit that's down by the water pump. Or is it a completely different Giemme/Gicar controller?
Pasquini has finally shipped the parts order that I placed last week, so I'm hoping to have those parts in 2 days, and then button the machine back up. Once I have a bell and PF coming, I can pop the top plate off in seconds, swap the bell, and the machine will be done.
I was eyeing the PF installed in the Group last night, and it clearly sits at an angle. I think some of that will go away with a gasket surface that's flat, but ultimately, I'd like to replace the bell and PF(as I've already said).
I picked up a Quick Mill Andreja Pro form a thrift store and am working on that right now. The size difference between the two is ridiculous. It really makes me like the Livia even more.
- hankbates
The controllers are greatly different, as is the front panel, which has a depression for mounting the touchpad versus a cutout for the switch. Nothing special about the brew switch, just double pole single throw. And, of course, the wiring....austinado16 wrote: I wonder if Pasquini sells a brew switch, and if so, if you could easily convert yours, just buy changing the wiring a little, and removing the flow sensor unit that's down by the water pump. Or is it a completely different Giemme/Gicar controller?
The control boxes are both the same size and mount identically, but there are lots more electronics inside the touchpad controlled unit.
Parts arrived today. I replaced the new "beveled" OEM style Group gasket with an orange Bezzera 8mm flat version and that has cured the massive leak between the top of the PF basket, and the Group gasket. I've ordered an OE style PF from Pasquini, so with the new gasket and a PF that has new ears, that'll resolve the issue. The green light is replaced and works. I added an electronic filter to the pstat, to keep it's contacts from being fried by the current being switched off and on to the heating element. I also replaced the missing "Steam" badge in the steam wand knob. I wrapped the boiler, re-mounted the controller and power relay, and put the body panels on.
I really appreciate everyone's help. It was a fun project, and I learned so much! Couldn't have accomplished this without all the help from you all, and from the library of Livia repair threads stored here.
First real use of it today. Made a nice Americano, via a double shot (13g of coffee) and using the hot water wand to fill the cup. No leaking from the group, and for a non-dialed in shot, with the wrong coffee, it was actually decent. I took the suggestion of discharging a few seconds of over heated water from the heat exchanger.
Here are a few glam shots (albeit still in it's testing location on the sink drain board)...
