OPV kit for Nuova Simonelli Oscar 2
Baristacris
#1: Post by Baristacris »
Hello there! Does anyone know where I can find an OPV kit for my nuova simonelli Oscar 2 in the USA?
vas
#2: Post by vas »
If you don't mind buying parts separately, you can make it the way I did, from ECM Giotto's OPV, which I bought from Stefano's. Other than OPV itself, you'll need a piece of 4x6mm PTFE tubing, two NS 07300364 STRAIGHT 1/8 fittings, one 1/8M to 1/8M BSP elbow fitting, one 1/8 BSP FFF tee fitting, 6mm barb tee, and a piece of 5x8mm silicone tubing. Here's the photo of how it looks (copied below). This is Oscar I, but it pretty much is the same machine.
Baristacris (original poster)
#3: Post by Baristacris (original poster) »
Hey! I'll definitely give it a try! Thank you!
#4: Post by Baristacris (original poster) »
Once installed, how is the bar pressure? Do you see a difference?
vas
#5: Post by vas »
Well, sure, I see that the pressure is now limited by the OPV. I set around 9.5 bar on a blind basket, so it stays up to around 9 while brewing.
#6: Post by Baristacris (original poster) »
So I installed the OPV kit from Elektros, but my machine isn't reading the water tank. Any clues as to why?
