Nuova Simonelli Musica - excess steam from group
emailmarkpotter
#1: Post by emailmarkpotter »
I recently got a simonelli musica and I am having a problem with excess steam coming from the group head whenever I activate the group. Any suggestions?
Video of cold run :
Video of hot run:
Thanks for the help!
Smo
#2: Post by Smo »
Water is boiling. Suggestion to lower the boiler temperature.
Aida Battle: Indigo Reserve from world renowned Finca Kilimanjaro in El Salvador
Sponsored by Aida Battle
emailmarkpotter (original poster)
#3: Post by emailmarkpotter (original poster) »
Done that. Lowered pressure stat down to 1 bar and it's still happening
Smo
#4: Post by Smo »
Jeff
#5: Post by Jeff »
It's an HX machine. You have to manage the temperature manually. This is done through flushing in a home setting.
See, for example, Managing the Brew Temperature of HX Espresso Machines
#6: Post by emailmarkpotter (original poster) »
This machine doesn't have a pid
Admin
#7: Post by HB »
The "hot" video shows a really long delay before water flows, which reminds me of a thermosyphon stall. I don't know the specific hydraulics of the Musica, but I'd look for slow leaks (e.g., OPV, group solenoid).
Versalab: maker and supplier of finest espresso equipment
Sponsored by Versalab
#8: Post by emailmarkpotter (original poster) »
Jeff wrote:It's an HX machine. You have to manage the temperature manually. This is done through flushing in a home setting.
I know about flushing but it seem a 15 second flush is pretty excessive to me.
kitt
#9: Post by kitt »
A couple of options to check;
1 - no return valve in the brew circuit, maybe causing HX to drain
2 - Small restrictor just after the pump, i had one of these once and it was partially blocked causing similar symptoms to this. From memory the restrictor is in a small brass fitting
lukeap69
#10: Post by lukeap69 »
Is your preinfusion on?
I had the same issue many years ago and the solution for me was to change the pressurestat to Sirai. Others reported different outcome but I neved had the same issue after.
You can check this video.
http://www.youtube.com/watch?v=wE3rXljK0BE
