No water nor pressure on Breville BES860XL
Hi I had Breville BES860XL for about 4 years now. I just changed its solenoid valve assembly about 2 months ago because its seems the pressure getting lower/inconsistent and did cleaning-decalcifying use vinegar-water 30-60 and after that was working back normally. After about 3 month, the espresso getting less and less pressure at its shower head (back to inconsistent again) and I decided to changed its pump (all new and original parts). Its getting worst after that. The pump has a normal noise indicate its working but after 2-3 seconds the noise become very weak and no water came out from its head and no pressure at its gauge at all. Steam wand working perfectly. I re-open again to see and put colour water in the tray (make it easier to detect) and saw that a water in the pipe from solenoid valve assembly that goes to shower head and pressure gauge cannot goes up (only half way) into its channel. Is this means a blockage in its solenoid valve assembly again? I try to contact Breville technical support but no luck. Please help.
Did you test the pump independently before you installed it?
I've had repairs where a "new" pump was defective. I'd pull the pump out and see if it's truly pumping water.
Nick
Nick
- slipchuck
Did you check the in line filter? Also, these models have been known to get clogged hoses
Good luck
Randy
Good luck
Randy
