New Marcfi single-group espresso machine and grinder from 1996
so i have been searching in the web for instructions and/or diagrams, exploded parts drawings, or something, no luck
it seems that even for the brand MARCFI this machine is not a very common product
moreover, MARCFI was closed shortly after producing this machine, there is no way to contact the company or distributors that may have some more info.
PO kept instructions, they say: Model S/U Serie P
and that wil give you nothing in a search
...TBC
...TBC
- pizzaman383
- Supporter ❤
Here are some https://www.espressounderground.co.uk/M ... s/2313.htm
http://www.sreweb.com/diagrams/marcfia.htm
https://www.ersatzteil-handel24.com/mar ... ng_EN.html
https://www.eunasa.com/en/article/list ... /16-marcfi
Curtis
LMWDP #551
LMWDP #551
- drgary
Regarding any Marcfi parts, you'll want to make sure you're dealing with the commercial lever machine and group, not the smaller manual home lever.
LMWDP#308
LMWDP#308
thank you , i can recognize some of the parts pictured in your links
i will need further dissasemble and analysis
links highly appreciated
i think this is the commercial one,drgary wrote:Regarding any Marcfi parts, you'll want to make sure you're dealing with the commercial lever machine and group, not the smaller manual home lever.
the home lever, i was told, was similar to lapavoni, my lapavoni filter holder is much smaller, lets take a look inside,
it seems that it was prepared for gas and electricity, but mainly operated with electricity by PO
it has a hose for fresh water and a hose to evacuate water excess, but this last one was conveniently closed to avoid installing the sewing system
it is my intention to use it without a fresh water entry, as it is a manual lever coffee water is coming from boiler, so my idea is to install a tube with an screwed cap directly onto the boiler, this way i will have to fill the boiler through it before use
i can not use a fresh water supply from the net so it is the only way i can go, i understand that this mod is fully reversible as basically a closed cap is like the original mod
please comment if you think this is impossible, and or comment on what kind of metal welding is expected, is the boiler brass ? or steel, or anyother metal ? pictures will follow soon
thanks
thanks
I can't really tell from just the pics but if this is an HX lever you will need positive inlet pressure or it won't work.
If it's a dipper tube machine then you won't necessarily but if it has autofill circuitry then you will need positive inlet pressure again
Best way to go is a flojet plumbed into an accumulator.
I would not get into boiler mods imo
