Need help regarding my old Rancillo S27
Hi everyone:
I am new to here. Recently my old Rancillo S27, which i loved so much for the past few years, encountered some problem. I will try describe it so that someone maybe can help me with some answer:
few weeks ago, after I turned the machine on and wait until the pressure rose to where it should be, but when I press the brew button, no water came out from the group head. I tried other brew buttons, it appears the same. The water ran a very short time (2s) and shut off. it does not produce the volume as it suppose be. So I remove the cover, here is what I found. The little LED indicator on the flow meter was instantly on, which should be rapid flashing when water ran through. I then unplug the wire on flow meter, pressed the brew button again, it seem running, hot water came out, but would stop about half way as it normally should be. I plugged the wires back on, press the button, no water came out, not even a running noise. The indicator LED on the brew button, just flash once without any click sound.
I first thought it would be the flow meter. So bought a new lid and replaced it. But the problem is still there, was not resolved.
Could anyone here help me to find out what exactly the problem is?
Really appreciated!
Ray
Really appreciated!
Ray
