Is that acrylic by any chance the same diameter as a dosing funnel I believe you turned for an HG-ONE? THNX
Spentpuck:
It is the same acrylic but probably not the same diameter. I have several different diameters and wall thicknesses that I have purchased for people and their different size PF baskets and the ones I used for trying to make the clear hopper. I tried 3 different sizes for it before I settled on the one in place now.
Stephen
I bought an acrylic tube with 60 mm outer diameter and it fits the Major perfectly. Tamper base as lid
The original hopper with a capacity of 1.7 kg is too much when you only buys 250 grams of coffee weekly.
for single dosing it prevents popcorning. It also gives you access to the burrs after dosing. For someone who roasts twice a week, its a hopper with the correct scale. And I doubt beans will get caught in this hopper as easily as they do in stock hoppers.
