Leaking Gaggia Classic pump
tag1260
#1: Post by tag1260 »
Anyone ever rebuild a leaking Gaggia Classic pump and get it to stop leaking? After my rebuild I decided to try backflushing my machine and afterwards found the top of my pump leaking. Must have been weak as I followed to backflushing of only 5 seconds run time.
Anyways, there is an o-ring around the top that should be the culprit if I could only fine one (or two but not 50 or 100) it might be an affordable fix vs buying a new pump. I measure 1.5mm x 13mm x 16mm (cs x id x od). Went to my local rubber shop where I get belts and hoses and o-rings and they didn't have anything but could order 100 for me so that made it not worthwhile.
Thinking of trying some silicone sealer.
Think it'll work?
Thanks
Jake_G
#2: Post by Jake_G » replying to tag1260 »
I wouldn't use silicone.
If you've got the dimensions correct, you can order a package of 4 viton O-rings in this size for $4 and change from hoseandfittings.com. Nitrile O-rings would be fine in this application and would be even cheaper, (though you'd probably get 10 for $4 instead of 4 for $1.50).
If you order tomorrow you get free shipping because they're cool like that and ship for free on Fridays.
Cheers!
- Jake
tag1260 (original poster)
#3: Post by tag1260 (original poster) »
Thanks. That makes it worth pursuing.
