La Pavoni milk frother pin
Hi! I have lost my pin (not sure what it's called but its a plastic pin that you move in order to get froth) for my Pavoni machine and hope to be able to 3D-print a new one. At the moment I'm using a toothpick.
Does anyone know the measurements of the pin? I was not able to find them online.
hi,
the dimensions are a bit hard to find, the spare part itself is slightly easier ( depending on how old your 'cappuccino automatic' is).
for one from before 2017 you need this pin:
https://www.theespressoshop.co.uk/Mobil ... -2214.aspx
which would cost about 8 euros including shipping.
So unless you own a 3d printer, it might even be less costly than having it printed.
cheers
Rob
cheers
Rob
LMWDP #647
Thanks! My machine is from the mid 90's, do you think it will fit?
I do own a 3d-printer, but yes since the dimension seem to be difficult to find it might be easier to order the spare part
As far as I know the cappuccino automatic didn't change from its introduction untill 2017 so this part should fit yours.
cheers,
Rob
cheers,
Rob
LMWDP #647
